Wyze Switch Automations
Automations help control your Wyze devices through Shortcuts, Schedules, and Device & Service Triggers. This reference article lists all of the triggers and actions available on Wyze Switch and Wyze Switch L.
💡 A trigger is what happens to start an automation, like a command. An action is the result of that trigger, or the task you want your device to do.
Wyze Switch Triggers
Wyze Switch Actions
Single Press - On
Single Press - Off
Double Press
Triple Press
Press and Hold
Turns on
Turns off
Has been on for
Has been off for
Turn on
Turn off
Turn on for
