Wyze Cam v1/v2 Mounting Kit
The Wyze Cam Mounting Kit gives you more options for placing your Wyze Cam.
  • The mounting kit is compatible with the original Wyze Cam and Wyze Cam v2. Not compatible with Wyze Cam Pan.
  • Use the 5-foot USB extension cable included in this kit to extend the reach of the 6-foot USB cable included with the Wyze Cam, for a total cable length of 11 feet
  • Metal mounting plate sticks to any surface using the included 3M adhesive tape
  • The metal mounting plate includes a center-hole and screw for added support when mounting to walls or ceilings
Learn more and order Wyze Cam Mounting Kit here.
Frequently Asked Questions
Q: How do I use the Wyze Cam v1/v2 Mounting Kit?
A: The Wyze Cam v1/v2 Mounting Kit can be used to mount your Wyze Cam v1/v2 to a wall or ceiling either by using the adhesive pad for a permanent fixture or by using the included screw to attach the metal plate for more temporary placement. The magnetic base of the Wyze Cam v1/v2 will hold strong to this metal plate, so you can even hang it upside down!
Q: Can the Wyze Cam v1/v2 Mounting Kit be used outside?
A: No, the Wyze Cam v1/v2 Mounting Kit is not intended for outdoor use. The Wyze Cam v1/v2 is not weatherproof and can be damaged by being used outdoors.
Q: Where can I use the Wyze Cam v1/v2 Mounting Kit?
A: You can use the Wyze Cam Pan Mounting Kit to mount your Wyze Cam v1/v2 on a wall or ceiling indoors.
