Wyze Cam Pan Mounting Kit
The Wyze Cam Pan Mounting kit gives you more options in placing your Wyze Cam Pan.
  • Compatible with Wyze Cam Pan only
  • 15’ Micro USB cable is compatible with Wyze Cam Pan and Wyze Cam v1/v2
  • The bracket contains an extra-strong, detachable magnetic base that screws into the bottom of Wyze Cam Pan
  • Hinge range of motion on bracket: 0° – 180° vertical
  • 6 cable clips included for easy cable management
Frequently Asked Questions
Q: What comes in the box?
A: In the box, you'll find the Wyze Cam Pan mounting bracket, a 15' micro USB cable rated to 2000mA, hardware for the mounting bracket, 6 cable clips, and an installation guide.
Q: How long is the micro USB cable?
A: The micro USB cable is 15 feet long. Unlike the Wyze Cam v1/v2 Mounting Kit, this will be a full micro USB cable rather than an extender.
Q: Where can I use the Wyze Cam Pan Mounting Kit?
A: You can use the Wyze Cam Pan Mounting Kit to mount your Wyze Cam Pan on a wall or ceiling indoors. With the extra-strong magnetic base that screws into the bottom of your Wyze Cam Pan, you can also stick your Wyze Cam Pan anywhere you'd stick a magnet without worrying about it falling down.
Q: How do I use the Wyze Cam Pan Mounting Kit?
A: The Wyze Cam Pan Mounting Kit can be used to mount your Wyze Cam Pan to a wall or ceiling by following the guides below. The adjustable hinge on the mounting bracket allows you to change the angle of your Wyze Cam Pan to best fit your needs and environment.
If you are mounting your Wyze Cam Pan upside down, make sure to rotate your Live Stream 180° by tapping on the settings icon in the upper right-hand corner of your Wyze Cam Pan's Live Stream, tapping on Advanced Settings, and toggling on Rotate image 180°.
Q: Can the Wyze Cam Pan Mounting Kit be used outside?
A: No, the Wyze Cam Pan Mounting Kit is not intended for outdoor use. The Wyze Cam Pan is not weatherproof and can be damaged by being used outdoors.
