No. Wyze Plug only records run time (on/off time) in the past 24 hours and average run time for the past 7 days.
- Can I dim my lamp using a Wyze Plug?
- Is Wyze Plug ETL Certified?
- What kind of power outlet can I use with my Wyze Plug?
- Can Wyze Plug report energy use?
- What kind of Wi-Fi does Wyze Plug support?
- What will happen to Wyze Plug if the power goes off?
- Can I fit two Wyze Plugs into the same outlet?
- Can Wyze Plug be used outside?
- What are the dimensions of the Wyze Plug?
- Will it automatically reconnect to my WiFi after an outage?"
- See more
