Yes, Wyze Plug has been ETL Certified. Wyze Plug has been tested at the ETL laboratory and found to meet all applicable standards and safety measures.
- Can I dim my lamp using a Wyze Plug?
- Is Wyze Plug ETL Certified?
- What kind of power outlet can I use with my Wyze Plug?
- Can Wyze Plug report energy use?
- What kind of Wi-Fi does Wyze Plug support?
- What will happen to Wyze Plug if the power goes off?
- Can I fit two Wyze Plugs into the same outlet?
- Can Wyze Plug be used outside?
- What are the dimensions of the Wyze Plug?
- Will it automatically reconnect to my WiFi after an outage?"
- See more
