How do I change the unit of measurement?
To change the weight unit of measurement:
  1. In the Wyze app, tap on your Wyze Scale.
  2. Tap on the gear to open Scale Settings.
  3. Tap Units, then select lb or kg.
  4. Return to the Wyze Scale screen.
Note: Shared users cannot change the unit of measurement.
