Yes, in your Scale Settings.
- In the Wyze app, tap on your Wyze Scale.
- Tap on the Settings gear > Export Data.
- Select the data range (the past Week, Month, Year, or Custom range).
- If you tap a Custom range, set a Start and End Date.
- Tap Export, the OK.
Have Apple Health or Health Connect? You may also be able to export your data from those sources instead.
