How do I change the unit of measurement? Brenda February 22, 2021 03:31 To change the weight unit of measurement: In the Wyze app, tap on the Wyze Scale. Tap on the gear to open Scale Settings. Tap Units, then select lb or kg. Return to the Wyze Scale screen. Note: Shared users cannot change the unit of measurement.
