How do I charge my Wyze Band?
To charge your Wyze Band:
Plug the charger into a standard USB port(5V,1A) on your computer or UL-certified USB wall charger. Attach the other end to your Wyze Band with the clip, making sure that the charging ports make contact.
Did you know? Your Wyze Band is fully charged right out of the box.
