How do I maintain my Wyze Band?
 Wyze Band maintenance tips:
  • Keep your Wyze Band clean.
    • As needed, wipe the band surface with a cloth dampened with fresh water.
    • Do not use bleach, organic solvents or other chemicals on the band.
    • Do not use soaps, shampoos, conditioners, perfumes, sunscreen, or lotions on the band.
  • Keep your Wyze Band dry.
  • When not in use, store your band in a cool, dry place.
    • Avoid direct sunlight, extreme high or low temperatures, or high humidity.
  • Do not disassemble your band.
