How do I change the Wyze Band screen brightness?
To change the screen brightness from the app:
  1. In the Wyze app, tap on your Wyze Band.
  2. Tap on Settings gear icon.
  3. Tap Brightness and confirm.
To change the screen brightness from the band itself:
Tap on the Wyze Band's screen to wake it up, then scroll and tap Setting > Brightness. Once changed, tap the Home icon to back out and save your changes.
