How do I change the time zone on my Wyze Band?
To change the Wyze Band time zone:
  1. In the Wyze app, tap on your Wyze Band.
  2. Tap on the Settings gear > Time Zone.
    1. If you've granted location permissions to Wyze, the default should display your current location.
  3. Tap to turn off the Set Automatically setting.
  4. Select the Time Zone you want and confirm.
