How do I sync the Wyze app with Google Fit?
Your Wyze Scale measurements can sync automatically to Google Fit! To set this up, you need to authorize Google Fit in your Wyze app.
To sync with Google Fit:
  1. In the Wyze app home tab, tap on the Wyze Scale.
  2. Tap on the gear to open Scale Settings.
  3. Tap Authorize 3rd-Party Apps, then Google Fit.
  4. Tap Authorize and follow the on-screen instructions.
Note: Support for Apple Health is coming very soon. Stay tuned!
Still need help?
