How do I maintain my Wyze Scale?
 Wyze Scale maintenance tips:
  • Keep your Wyze Scale clean.
    • As needed, wipe the scale surface with a cloth dampened with water.
    • Do not use bleach, organic solvents or other chemicals on the scale.
  • Remove the battery if you won't use your scale for over a month.
  • Avoid shocks. Don't jump on it.
  • Do not disassemble your scale.
Still need help?
