Is there a stopwatch or timer on Wyze Band?
Yes, with the Tools function.
You can enable the Stopwatch feature under the Tools function in the Wyze app.
To enable the Stopwatch function:
  1. In the Wyze app, tap on your Wyze Band.
  2. Tap the plus + sign to add a function to your band.
  3. Tap the plus + sign next to Tools.
  4. Tap Save.
  5. Tap on the Tools function to open it.
  6. Next to Stopwatch, tap the toggle to On.
You can now use the Stopwatch on your Wyze Band.
