Why does the Base Station only support 4 cameras?
For the most stable and reliable connection.
Wyze Base Station is the WiFi access point for your Wyze Cam Outdoor. The more cameras attached to the Base Station, the heavier the strain on bandwidth, and the more it affects the live stream.
We've thoroughly tested the stability of the Base Station with four (4) cameras, and this amount the most stable when all four cameras are live streaming.
For now, if you have more than four Wyze Cam Outdoor cameras, you'll need to buy another bundle with a new Base Station.
