No. Wyze Video Doorbell does not support a microSD card. All recorded events will be stored in the cloud.
- How do I enable VOIP calls on Wyze Video Doorbell?
- I have 2 doorbells and 1 chime. Can I replace both with Wyze Video Doorbells?
- Can I plug Wyze doorbell directly into AC power?
- Does Wyze Video Doorbell have a USB port?
- Can I use the doorbell with both my old chime and Wyze Chime?
- Can I set up multiple chimes?
- Can I buy another Wyze Chime?
- If I have 2 mechanical chimes will both need to be bypassed?
- How do I change the Wyze Chime sound?
- Does Wyze Chime need to be wired?
- See more
