Does Wyze Video Doorbell have a USB port?
Yes, but using it would void the warranty.
Wyze Video Doorbell has a micro USB port on the back of the device, hidden under a protective rubber seal. This micro USB port should not be used to power your doorbell. It was only intended for production purposes.
Peeling off the protective rubber seal to access the micro USB port will compromise the IP65 weather resistance and void the warranty.
