Does Wyze Thermostat work with motion sensors?
Yes, Wyze Thermostat can with Automations.
Wyze Thermostat works with Wyze Sense sensors seamlessly with Automations. Set your motion sensor to have the thermostat turn on the heat when you enter a room, or turn off the AC when a door's been ajar for a while.
