Can I create a schedule for Wyze Thermostat?
Yes, that's one of the core features!
Create a schedule to turn your thermostat down when you're usually away from home, turn on the AC when you know it'll be hot on Saturday, or always have your heat on in the evenings.
Wyze Thermostat is smart, and you can set up Temperature Preferences and create schedules for every day, specific days, or the entire week from the Wyze app.
Related article: Scheduling with Wyze Thermostat
