How do I select the correct slope?
Choosing the correct Slope for your zone is incredibly important. If your zone is on a steep hill, for example, it may experience water “running off” and less water is absorbed into the soil.
To select your slope:
In the Wyze app, tap on your Wyze Sprinkler, then select your Zone. Tap Slope.
Choose between the following Slope options:
  • Flat if your slope is < 3%
  • Slight if it is between 4% - 6%
  • Moderate if it is 7% - 12%
  • Steep if it is above 13%
