What is Precipitation Rate?
Spray heads have different flow rates which means they water the zone more or less quickly (measured in inches per hour).
We automatically select the Precipitation Rate based on your spray head type, but you can update it in the Wyze app if you feel it’s not correct.
How do I calculate my Precipitation Rate?
  1. Use our built-in calculator in the Wyze app.
    • This will require you to look up the spray head flow rate, count the number of sprinkler heads in the zone, and know the rough area of the zone.
  2. Manually enter the precipitation rate in inches per hour.
Your spray head type influences your Precipitation Rate. Check out: How do I identify my spray head type?
