Overload Protection
Wyze Plug Outdoor cuts off power at 20A.
No need to worry about overloading the outdoor plug - if there's a circuit shortage, or the device is over loaded, the plug cuts off the power at 20A. This is automatic, and applies to both outlets combined.
Important: Wyze Plug Outdoor should be plugged directly into your power outlet. We do not recommend connecting the outdoor plug to an extension cord as this could result in damage to your Wyze device and void your device's warranty.
