To set up your Wyze Plug Outdoor:
- In the Wyze app, tap Home, then tap the plus sign + on the top right.
- On the Add menu, tap Device.
- Tap Power & Lighting > Wyze Plug Outdoor.
- Insert your plug into a power outlet.
- Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Connect.
- On the next screen, you'll see your plug(s) connecting to the network.
Once connected, name your plug's outlets.
- Tap on the first outlet's name, then type in the pop-up to edit.
- Tap on the second outlet's name, then type in the pop-up to edit. Tap Save.
- You’re all set. Enjoy your new Wyze device!
Important: Wyze Plug Outdoor should be plugged directly into your power outlet. We do not recommend connecting the outdoor plug to an extension cord as this could result in damage to your Wyze device and void your device's warranty.
