How to remove Wyze Video Doorbell once installed?
If you've installed your new doorbell and want to remove it, follow the steps below.
To remove our Wyze Video Doorbell:
Before starting, turn off the power to your doorbell. At your electrical panel, switch off the circuit breaker for your doorbell.
  1. At your doorbell, press hard inwards and up. This will unlock the doorbell from the wall plate or wedge.
  2. Work backwards using the Installation Guide.
    • Remove the wire caps, disconnect the wires, and remove the wall plate or wedge.
Important: Do not switch on power at the circuit breaker until you have wired and installed new doorbell.
Still need help?
