How do I charge Wyze Handheld Vacuum?
Connect the charging cable, then plug into an outlet.
There's no extra charging dock or station needed for Wyze Handheld Vacuum. Simply attach the included USB Type-C power cable to the vacuum, and attach the other end into an adapter compatible with 5V-2A. Then plug it into a power outlet.
Note: Wyze Handheld Vacuum will not charge with a C2C cable. You must use the included A2C cable.
