Does Wyze Video Doorbell support detection zone settings?
Yes, but check your Wyze app version.
The Detection Zone feature is supported in Wyze app version 2.19+. Be sure to update your Wyze app and your Wyze Video Doorbell's firmware to the most recent version so that you see the feature.
Then, you can update your Detection Zone settings from the Wyze Video Doorbell device page by tapping the Settings gear > Detection Settings.
