How do I change the spotlight's brightness?
To change the spotlight's brightness level:
  1. In the Wyze app, tap on your Wyze Cam v3.
  2. Tap the Settings gear on the top right.
  3. Tap Accessories > Spotlight.
  4. Under Brightness Level, tap Low or High.
    • Low is best for indoor use, like in a garage or entryway.
    • High is best for outdoor use, like near the front door or driveway.
