Skip to main content
How do I install a microSD card in my Wyze Cam Outdoor?
Brenda
To install a microSD card in a WCO:
- Pull the base away from the bottom of your camera.
- Lift and pull aside the protective cover labeled SD CARD.
- Insert the microSD card into the slot, pressing it in fully until it clicks.
- The metal contact pins must be facing down (see below).
- Replace the protective SD CARD cover.
To install a microSD card in Wyze Base Station:
- Find the SD card slot on the side of your base station.
- The metal contact pins must be facing upwards (see below).
Have more questions?
Submit a request
