Wyze Floor Lamp Assembly Instructions
Assembling your Wyze Floor Lamp should only take a few moments. Most parts are already assembled and just need to be twisted to tighten!
To assemble your Wyze Floor Lamp:
  1. Remove all lamp parts from the packaging.
  2. Pull the cord through the base to tighten the pole connections.
  3. Screw the upper pole into the gooseneck.
  4. Screw the upper pole into the lower pole.
  5. Screw the lower pole into the base.
  6. Screw the bulb assembly into the gooseneck.
  7. Insert plug into the power outlet.
Here's a Wyze Floor Lamp diagram of the how the base, poles, gooseneck, bulb assembly, and cord switch should be put tightened.
wyze floor lamp assembly
