How does the Wall Mount Base work?
It holds your vacuum, and all its accessories.
Use the included Wall Mount to store your Wyze Cordless Vacuum. It can be used to hold the main unit, crevice tool, and 2-in-1 dust brush.
Does it have to be near a plug?
If you want to charge it while it's mounted, then yes. You'll need to install the wall mount near a power outlet. But if not and it's just for storage, it can be mounted anywhere.
