When should I use the attachments for the cordless vacuum?
For those hard-to-reach, too tight, off the floor areas.
  • Use the 2-in-1 Brush tool when a softer touch is required.
  • Use the mini-motorized brush for a deeper clean to remove dust particles and mites in bedding, carpeted stairs, and more.
  • Use the extension hose when you need more flexibility when cleaning.
  • Use the crevice tool to pick up crumbs and dirt in corners, nook, and hard-to-reach areas.
Note: Wyze Cordless Vacuum comes with the Aluminum Tube Assembly (long tube), Motorized Floor Brush, 2-in-1 Brush, and Crevice Tool.
