Where can I use Wyze Cordless Vacuum?
Anywhere indoors and where it's dry.
The cordless vacuum performs best when used indoors, on dry surfaces, bare floors, and carpets with short and firm textures. You can switch to handheld use by attaching the accessories after removing the floor brush and aluminum tube.
Use attachments to clean areas like your sofa, bed, ceiling, and stairs.
Additional Notes:
  • We do not recommend using Wyze Cordless Vacuum on thick or plush carpets.
  • The cordless vacuum comes with the Aluminum Tube Assembly (long tube), Motorized Floor Brush, Crevice Tool and the 2-in-1 Brush tool. You can purchase additional attachments at Wyze.com.
