- Can the motorized brush head be turned off?
- How do I check the battery level?
- Can I add Wyze Cordless Vacuum to the Wyze app?
- Does Wyze Cordless Vacuum connect to Wi-Fi?
- How long does it take to fully charge Wyze Cordless Vacuum?
- What objects should I avoid while vacuuming?
- Is Wyze Cordless Vacuum a wet/dry vacuum?
- Does the cordless vacuum stand up on its own?
- Can Wyze Cordless remove pet hair from clothes and bedding?
- When should I use the attachments for the cordless vacuum?
- See more
