Wyze Cam Vase has a hole at the bottom to route your camera's cable through. It also has non-slip pads to elevate the vase for a clean, no-visible-wire setup.
- Introducing Wyze Cam Vase
- How do I install the camera into Wyze Cam Vase?
- Is Wyze Cam Vase weatherproof?
- Can my Wyze Cam get hot in the vase?
- How do I clean Wyze Cam Vase?
- Where does the camera's power cable go?
- Which cameras are compatible with Wyze Cam Vase?
- Will the vase impact the view or video quality?
- Is Wyze Cam Vase fragile?
- Can I put real plants into Wyze Cam Vase?
- See more
