How do I install the camera into Wyze Cam Vase?
To install your Wyze Cam into Wyze Cam Vase:
  1. Make sure your Wyze Cam is compatible.
    • Wyze Cam v3, v3 Pro, and v4 are compatible with Wyze Cam Vase.
  2. Route the camera's power cable through the hole in the bottom of the vase.
  3. Slide the camera into the vase!
    • Try to not drag the camera body or lens along the inside of the cement vase, which can damage the device.
  4. Position the included plastic plants to make it look realistic and totally not like a camera in a vase.
No need for screws, adhesives, or additional padding - the camera fits snugly and securely.
