Wyze Solar Cam Pan / 2K Device Details
Color: White
Finish: Textured Matte
Materials: Body: Polycarbonate; Lens: Glass + Plastic
Camera Dimensions: 124 mm (H) x 60 mm (W) x 91.8 mm (D)
Camera Weight: 12.66 oz (359 g)
Camera + Solar Panel Weight: 18.94 oz (537 g)
Powering Methods
Power Cable: Tupe-C to USB-A
Cable Length: 2 feet (0.6 m)
Power Adapter Output: 5V/2A (not included)
Power Input: 110-240 V
Integrated Solar Panel 1.8 W)
Battery: 6400 mAh, non-removable Lithium-ion battery
Charging time: 0-100% in 4-6 hours using the provided cable/adapter
Battery life: Up to 2-6 months, not connected to power
Mounting Features
Camera Mounting Bracket
Audio & Video
Resolution: 2394 x 1296 (2K)
Camera
Image Sensor: 1/2.7'' CMOS
Digital zoom: 8x
Field of View: 130° (D) + 108° (H) + 57° (V)
Pan/Tilt Range: 360° Pan + 70° Tilt
Night Vision
2 IR LEDs (850 nm) Color Night Vision
Spotlight LEDs (100 lumens)
Video
Video encoding: H.264
Frame rate:
- Day time video: 20 FPS
- Night vision: 15 FPS
Audio
Siren: 105 db
Built-in microphone, digital
2-Way Audio
Rotation Speed
Vertical: up to 45° per second
Horizontal: up to 36° per second
Alerts
Push notifications
Storage
Cloud Storage
Stored in the AWS Cloud*
- Wyze Services subscription required
Local Storage (microSD card required):
- Supports 8-32 GB microSD cards in FAT32 format
- Supports up to 512 GB microSD cards in exFAT format
Local Storage
Connectivity
802.11 b/g/n 2.4 GHz, Wi-Fi 4/5/6
BluetoothⓇ Setup
Supports WPA and WPA2 protocols
Integrations
Alexa, Google Assistant, IFTTT
Phone Compatibility
Supports Android 10.0+ and iOS 16.0+ or later
Operating Temperature
-4°F - 122°F / -20°C - 50°C
Weather Resistance
Indoor and outdoor (IP65)
Language
English
Warranty
1-Year
