Wyze Solar Cam Pan / 2K Installation Guide
While following the Wyze Solar Cam Pan 2K Setup Guide, you'll be prompted to install your camera. Follow along with this video and article to install your Wyze Solar Cam Pan 2K.
What's in the box?
  • Wyze Solar Cam Pan 2K x1
  • Solar Panel x1
  • Camera Mounting Bracket x1
  • Camera Mounting Kit x1
  • USB-C to USB-A Charging Cable x1
  • Camera Mounting Drilling Guide x1
  • Solar Panel Mounting Bracket x1
  • Solar Panel Mounting Kit x1
  • Quick Start Guide x1
  • Outdoor Installation Guide x1
Note: A 5V/2A power adapter is required to charge Wyze Solar Cam Pan 2K using an outlet.
  1. Follow along in the Wyze Solar Cam Pan 2K Setup Guide. Once successfully paired, tap Next.
  2. Ensure you have the required tools. Tap Next.
    • You will need a ladder and a Philips-head screwdriver.
  3. Review the series of installation tips, tapping Next on each.
    1. Avoid pointing the camera at trees and busy roads.
    2. Position your camera for better motion detection.
    3. Mount the camera 7-10 feet up, angled 30° down.
  4. Check your Wi-Fi Strength. Tap Next.
  5. If you have a strong connection, tap Next.
  6. Choose how you'd like to install your Wyze Solar Cam Pan 2K and solar panel.
    1. Tap Install Together to attach the solar panel to the camera before mounting.
    2. Tap Install Separately to mount the solar panel and camera separately.
  7. Once installation is complete, follow the in-app instructions to complete setup.
  8. You're all set! Tap Done.
