Does Wyze Battery Video Doorbell work with a chime?
Yes, it works with several chime options!
Wyze Battery Video Doorbell works with Wyze Wi-Fi Chime, or you can use your own mechnical chime with a Wyze Chime Controller (both not included). Another option is to use your Wyze Cam as a chime, where your camera will play a chime when the doorbell is pressed (set up in your Device Settings).
