Yes, and you can receive notifications whenever motion is detected (using the body heat infrared sensor and edge algorithm.). With a subscription to Cam Plus, you’ll be able to configure alerts to detect people, pets, packages, and more.
- Is Wyze Battery Video Doorbell weather resistant?
- Is motion detection available on Wyze Battery Video Doorbell?
- Can I use a Wyze Cam as a chime for Wyze Battery Video Doorbell?
- Where can I install my Wyze doorbell?
- Does Wyze Battery Video Doorbell work with a chime?
- How long is the battery life for Wyze Battery Video Doorbell?
- Does Wyze Battery Video Doorbell use batteries?
- How long does it take to install Wyze Battery Video Doorbell?
