Wyze Window Cam Setup Guide
Before you begin setup:
  3. Unpack your Wyze Window Cam box, removing all plastic and packing materials.
    • Be sure to remove the plastic film from the lens.
  4. Plug each camera you want to set up into power using the included USB cable and power adapter.
    • The camera’s status light will turn solid red when powered. When flashing, it’s ready for setup.
To set up your Wyze Window Cam:
  2. On the Add menu, tap Device.
    • If Bluetooth is enabled, your camera may be found automatically. Tap Set Up to skip to pairing.
  3. Tap Cameras > Wired Camera > Wyze Window Cam.
  5. If Behind the camera lens, single-press the SETUP button. It will say “ready to connect”.
    • The camera may say “ready to connect” without pressing the SETUP button. If so, continue with setup.
  6. In the app, check the box next to I heard, “Ready to connect”.
  7. Tap Begin Setup.
  8. If BluetoothⓇ hasn’t already been enabled, you’ll be prompted to allow BluetoothⓇ access. Tap OK.
    • If BluetoothⓇ has already been enabled, it will skip to the next step.
  9. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Connect.
    • Tap the icon in the password field to display the password to ensure it was entered correctly.
  10. After the camera is set up and connected, it will say "Wi-Fi connected, setup complete”.
  11. Tap Complete. Your camera is set up, now it’s time to mount your device.
    1. Follow along in the Wyze app to install the mounting sticker and mount your camera.
    2. Then then continue below.
  12. Name your Wyze Window Cam  using the text field, or by choosing a suggestion.
  13. Tap Next when done.
  14. You may have a prompt for a free trial of Cam Plus, or to attach your camera to an existing subscription. Tap Continue, and OK if prompted.
  15. Set up some automations on the Things to Try* page, or tap Skip and Finish.
  16. You’re all set. Enjoy your new Wyze Window Cam!
