You want to know what the different status lights mean on your Wyze Window Cam.
Wyze Window Cam Status Light Guide
Wyze Window Cam Status Lights: During Installation
- Solid red – The device is powered on and initializing.
- Flashing red – The device is ready to connect.
- Flashing red and blue – Connection is in progress.
- Flashing blue – The device is connected and finishing setup.
- Solid blue – The device is working properly.
Wyze Window Cam Status Lights: After Setup is Complete
- Solid red – The live stream is being viewed, or a recording is in progress.
- Quickly flashing red – Siren is in use.
- Solid blue – The device is working properly, and no operations are running.
Note: The status light is located on the front of the camera, under the lens. The camera status light will be turned off by default after setup to reduce reflections on the glass. It can be turned back on in the Advanced Settings.
