How do I remove the mounting sticker from the window?
To remove the adhesive from a window:
  1. Remove the camera from the mounting sticker.
  2. Use heat from a hair dryer to soften the adhesive on the glass.
  3. Scrape or pry the sticker from the glass with a plastic card or scraper.
  4. Use isopropyl alcohol to remove any stubborn residue from the glass.
  5. Wash the glass with soapy water, then rinse and wipe completely dry.
If mounting the camera in the same area, ensure the glass is completely dry before applying the new mounting sticker.
