How does Wyze Window Cam compare to Wyze Window Mount?
Wyze Window Cam is built specifically to be used behind window glass. Unlike our other Wyze cams that work with our Wyze Window Mount accessory, Wyze Window Cam has several key differences.
Wyze Window Cam Wyze Window Mount
  • Wyze Cam w/ Built-In Adhesive
  • Peel and Stick Mount
  • No IR Lights
  • No IR Cut
  • No Spotlight
  • Extra-Long Cable Included
  • Mount Only, Wyze Cam* Sold Separately
  • Silicone Mount
  • IR Lights
  • IR Cut
  • Spotlight
  • Power Cable Not Included
* Wyze Window Mount is compatible with Wyze Cam v3, Wyze Cam v3 Pro, Wyze Cam v4, and Wyze Cam OG series cameras.
Unlike our other Wyze Cams that are not made to be used behind glass, Wyze Window Cam has been built to reduce glare and mount easily. We removed the IR lights and spotlight feature entirely, and put the adhesive directly onto the front of the camera for a strong, hassle-free mount. We even included an extra long cable and cable clips for tidy cord management.
