You'll receive 3 Wyze Leak Sensors and 1 probe in a single pack.
- What is the IP rating for Wyze Leak Sensor and Probe?
- What kind of leaks does the leak sensor detect?
- How big does a leak need to be to be detected?
- How long does the leak sensor's battery last?
- Does the leak sensor need to be hardwired?
- How long is the leak sensor probe?
- Can I order an extra Wyze Leak Sensor Probe?
- How many leak sensors and probes come in a pack?
- What are the leak sensor and probe used for?
- What is the difference between the leak sensor and the probe?
- See more
