Can I order an extra Wyze Leak Sensor Probe?
Yes, you can buy a standalone 2-pack.
Your Wyze Leak Sensor order comes with 3 leak sensors and 1 leak sensor probe in the box. If you'd like additional probes, you can order a standalone 2-pack in the Wyze Store.
