How do I change the unit of measurement?
To change the scale's unit of measurement:
In the Wyze app
  1. In the Wyze app, tap on your Wyze Scale S.
  2. Tap on the gear to open Scale Settings.
  3. Tap Units, then select lb or kg.
  4. Return to the main Wyze Scale S screen to save your settings.
On the back of your Scale S
Find the UNIT/RESET button, press it to change the units between lb with kg.
