Wyze Scale device maintenance tips:
- Keep your scale clean.
- As needed, wipe the scale surface with a cloth dampened with water.
- Do not use bleach, organic solvents, or other chemicals on the scale.
- Remove the battery if you won't use your scale for over a month.
- Avoid shocks. Don't jump on it.
- Do not disassemble your scale.
Note: This applies to the original Wyze Scale, Wyze Scale S, Wyze Scale X, Wyze Scale Ultra, and Wyze Scale Ultra BodyScan.
