Wyze Buds produce stereo sound. You can also adjust the EQ in the Wyze app!
- Can you adjust the audio levels for Wyze Buds?
- Do Wyze Buds have a mic?
- Which Wyze Buds version has the best battery life?
- Can I control the volume on my Wyze Buds?
- Does Wyze Buds support wireless charging?
- Can I use third-party ear tips?
- Can I customize the EQ of Wyze Buds?
- Can I connect Wyze Buds to two devices at the same time?
- How do I check the battery level on Wyze Buds?
- Do Wyze Buds produce mono, stereo, or surround sound?
- See more
