Can you adjust the audio levels for Wyze Buds?
Yes, you can adjust the audio levels in the Wyze app.
You can customize your audio levels using the equalizer in the Wyze app.
  1. In the Wyze app, tap on your Wyze Buds.
  2. On the top right, tap the EQ icon to the left of the Settings gear.
  3. Select a preset, or tap and drag to customize your levels.
  4. Tap above the tab to save your changes.
